XM Roadie II receiver - anyone install one of these?
Old 09-28-2005 | 11:20 PM
Scream And Fly's Avatar
I have this XM Roadie II receiver that I'm going to install in the Z28. Before I do, I was wondering how any of you routed the antenna wire?
Thanks!
Old 09-28-2005 | 11:27 PM
95GRNZ's Avatar
Re: XM Roadie II receiver - anyone install one of these?
Pictures of my installation are here.
I did have a Roady 1 at that time, but now I have Roady 2 in the same spot.
I installed the antenna on top of the dash and routed the wire along the front edge of the windshield to the passenger side and from there behind the glovebox to the center console.
Hope this helps.
TS
Old 09-28-2005 | 11:44 PM
That helps a lot, thanks! So, you don't have to mount the antenna outside? I would much rather get away with mounting it on the dash. Any negative effects from that?
Old 09-28-2005 | 11:48 PM
95GRNZ's Avatar
No, it doesn't have to be outside. I just put double-sided tape on it and put it on top of the dash, as far to the front edge as possible wihout having anything (moldings, wipers etc.) block the view to the sky.
So far I have not have had any problems with reception.
Old 09-29-2005 | 04:22 PM
jfischer's Avatar
I put mine just ahead of the big vent in the middle of the dash (closer to the glass), and ran the wire down the vent and pulled it down to the console.
I have Sirius right now, but the antenna and wiring are virtually identical. Reception is fine with our huge front window, at least for me.
11-18-2023 07:21 PM
k1996z28
04-06-2015 11:55 PM
Rde Bandit
03-21-2015 10:17 PM
cmyname1
02-16-2015 08:33 PM
Quick Reply: XM Roadie II receiver - anyone install one of these?
