02 sims for off road Y pipe
Old 09-20-2004 | 08:06 PM
harnickhouse's Avatar
Just put off road y pipe on my 98 Z-28 and now the back two 02 sensors are not plugged in. Will this affect the performance in what the ecm will read and will 02 simulators correct this?
Old 09-20-2004 | 08:41 PM
Timberwolf's Avatar
Re: 02 sims for off road Y pipe
the sims tell the computer that everything is as it should be. if you need a set of sims, let me know. I still have mine and am not using them.
Old 09-20-2004 | 08:51 PM
Would the 02 sims affect the power? What if I did'nt put the 02 sims in? I know it works with the computer, but does it need this good 02 reading to perform its best?
Old 09-20-2004 | 08:56 PM
teke184's Avatar
rear o2 sensors have ZERO impact on performance. malfunctioning, unplugged or simulated the car will run the same.
only thing they do is trigger the SES light to tell you something is wrong with the cats.
BLK1997Z28
05-07-2015 03:01 PM
Queens94z28
03-23-2015 08:06 AM
joffer00
Exhaust System
12-22-2014 03:25 PM
andy98Z
01-01-2003 04:07 PM
Quick Reply: 02 sims for off road Y pipe
