2002 SS Coolant Question
My 2002 SS with 500 miles has a bubbling sound after it is turned off. Sounds like coolant bubbling or flowing, maybe to the coolant recovery tank. Any other members hear this sound, is it normal? Thanks for your help.
See if you only here this noise after you have been running the AC, you may be hearing the high and low side pressures balancing out, listen closely to the accumulator, thats where alot of noise comes from, its normal though.
98 Z28 A4 2.73 aluim. driveshaft
Free mods SLPlid & bellows
BMR LCA & SFC
Stock: 288rwhp 311rwtq
BMR LCA & SFC
It makes boiling sounds every time I turn off the car no matter if the AC was running or not. Temp gauge reads about 195-200 degrees all the time. Has done this since new, a little over a week now. I put my hand on the coolant recovery tank and can feel vibrations that correspond with the sounds. Do all LS1's do this or is something wrong?
Mine does that too every once and a while, its just the coolant running to the recovery tank. No need to worry.
2002 WS6
Mods: K&N FIPK
Granatelli MAF
Hypertech programmer III
160 deg powerstat
SLP Loudmouth
2002 WS6
Mods: K&N FIPK
Granatelli MAF
160 deg powerstat
SLP Loudmouth
Since your car runs between 195 and 200 all the time you need to get the 160 powerstat..thats what I did and my needle barely gets above 160 or so. Just a little advice
1998 Camaro SS A4 #2,515 OF 3017
NBM w/ grey leather
T-tops, all GM options
MODS:
-SLP dual-dual (came with car)
-Hypertech 160 thermo
NBM w/ grey leather
MODS:
Problem found. The factory put the radiator cap on with one end of the rubber gasket bent over. It was not making a good seal. I put the cap back on with the gasket in the correct place and the bubbling coolant noise is gone. Thanks for all your inputs.
2002 SS SLP #8447
2002 SS SLP #8447
Sergio
01-27-2016 04:27 PM
Dan_the_ManZ28
02-21-2015 02:01 PM
