2k-3k bog
Old 06-23-2004 | 05:37 PM
muraoka's Avatar
2k-3k bog
i have a 99ss. ever since i got it it's bogged or stumbled between 2k and 3k. it doesn't all ways happen and it happens at different throttle positions. anyone have any ideas?
thanks matt
Old 06-23-2004 | 05:49 PM
Gloveperson's Avatar
Check every filter there is. Also look at your plugs/wires.
Old 06-24-2004 | 12:02 AM
muraoka's Avatar
thanks i'm new to the ls1 and haven't payed much attention to the car since i got it. spend most my time with my 97, but i just broke a ring and have to race the ss for a while.
Old 06-24-2004 | 04:56 AM
AL SS590 M6's Avatar
Moderator
Could be carboned up. Is it using any oil?? Sucking oil into the intake??
Old 06-27-2004 | 09:15 PM
whoa guy's Avatar
my z used to do the exact same thing. never did it at wide open throttle. clean your mass air sensor w/a Q-tip, but be really careful. dont use any cleaning agents. I hope this solves your problem. its been known that using oil air filters like a k&n can "gunk" up the maf sensor which causes incorrect readings.
Old 06-28-2004 | 12:17 AM
H/C LS6Z's Avatar
I'd agree with the first guy check your plugs/wires my bro's car used to do the same thing before he changed the plugs/wires
Old 06-28-2004 | 12:26 AM
muraoka's Avatar
it doesn't use any oil. did find a bad plug wire. it seems when i race the car i always get a ses (rear 02s). thank you all for your suggestions. hope i can find this so far nothing seems to help.
thanks matt
Alibi
08-01-2015 07:50 PM
Bz8
07-13-2015 04:46 PM
XKnightRider
01-04-2003 09:40 PM
aziroc
12-10-2002 04:27 AM
transamtom
09-11-2002 04:28 AM
Quick Reply: 2k-3k bog
