425HP LS1. What would I need?
That's my goal for this car, it'll take a while, granted. What would I need to generate 425RWHP (or at least over 400HP) consistently and reliably? The mods i have in the works right now are a new lid and dynomouth-like cat back. I know that'll put me barely at 300, so don't remind me.
So what would i need? I put my faith in your experience.
Re: 425HP LS1. What would I need?
oh yeah probably should have mentioned I have A4. I've heard the 02 model autos didn't detract too much from overall hp, but it probably makes it a little harder to reach my goal.
could you go into more detail with "all the bolt-ons"? I know the air lid and new exhaust are in there, but what else do we have? A ram air kit i assume? Is a supercharger on that list? I'm not too keen on using spray...
check around to other LS1 boards as well... You may find the F13 cam could be what you are looking for..
You dont have to go huge.. and it wont be harder with a 2002.. in fact, part of the modding is already done.. LS6 intake.. !EGR ... the rest is you really.. study and pick wisely and be rewarded..
Thanks guys, this all really helps a lot. Now i have heard of you guys talking about the Trex cams and how unruly they can be, does anyone know of any comparisons between brands or reviews for different cams? Also headers will probably be a big issue as well...are LTs pretty much the way to go, or are there better things out there?
It's been a while since i've found a forum so willing to help. thanks again!
call up trevor at texas speed and performance, tell him what you want and he'll tell you exactly how to get it.
no ram air is needed really.
the list is pretty short:
-headers
-233 torquer cam (just had mine installed on stock heads and it's awesome)
-stage 2 (or equivalent) LS1 heads
-dyno tune
you'll probably want a decent torque converter, but not sure how that works...been out of the auto scene for a while.
i did about 390 hp with the Torquer cam (382 actually but the clutch was slipping and the tune wasn't fantastic) and that was on stock heads!! the torque on that cam is great to, considering LS1s tend to be low on torque. it was right around 375#s at 5000rpms, with 330#s at 3000rpms.
decent heads would pick up 35hp NO PROBLEM!
-headers
-dyno tune
Originally Posted by SnakeSkinner28
Get all the boltons and then get the T-Rex cam from Thunderracing. That will be your 415 at the wheels right there.
Crabhart, instead of looking to get a certain HP on the dyno, why not try for a certain ET. Take a converter for instance, it'll help you run quite a bit quicker on the track and street but will actually make you dyno lower. Then you could also change gears, again no dyno gains but you will be quicker. Dyno numbers are for bragging and bench racing.
That's a good idea. However i haven't raced it yet, so i'm not exactly sure where i'm starting from.
I'd like to be somewhere in the 11 range, maybe a 11.5-11.8.
When i replace the torque converter, would Fuddle be a good brand? I've heard a lot of good things about them.
On a quasi-related topic, the last comparison test of the 2002 Z28 in Car and Driver said the M6 and the A4 had a ET difference of about .2 or less. For that reason I stopped being self conscious of my A4.
Now if i can just find an air lid i can get started.
Originally Posted by ls1650
its harder to reach over 400rwhp with a4's. much eaiser with m6's but it is possible. headers, gears, cam, head, and a good tune should get u there.
