5.3L truck V8 vs 5.7L LS1
What is the difference between the 5.3L V8 Found in the 2002+ GMC Yukon / Tahoe and a 5.7L LS1?
From an internal point of view, what would it take to make the 5.3 into a 5.7 or a 6.0?
Crank? Pistons? Bore?
Is the 5.3L a sleeved aluminum block?
Re: 5.3L truck V8 vs 5.7L LS1
Originally Posted by SSpdDmon
I believe it's the same block, just less displacement in the stroke. Different cam, heads, and intake too I think.
Can the 5.3L be bored to 4.00 without having to siamese cylinder sleeves?
- The 5.3 / 5.7 / 6.0 all share the same crank (3.62").
- The 4.8 & 5.3 share the same bore (3.78"). Thus, the 5.3L dimensions are 3.78" x 3.62" . The bore is what seperates all the 5.3 / 5.7 / 6.0 engines.
This info can be found right off of GM's website:
- 4.8L = 3.78" x 3.27"
- 5.3L = 3.78" x 3.62"
- 5.7L = 3.89" x 3.62"
- 6.0L = 4.00" x 3.62"
All 3 engines (excluding 4.8, as I'm not sure about it) use different heads. You'll see some guys run 5.3L heads on their LS1 because they flow the same, but have smaller chambers for increased compression. The 6.0L truck heads are almost identical to the LS6 heads in flow (chamber size) capability, but they have LARGER chambers than those of the LS1 or LS6, thus, lower compression in comparison.
While the LSx (1, 2, 6, 7) series of engines are aluminum blocks with steel sleeves, I don't know about the truck (4.8, 5.3, 6.0) blocks, because they're cast iron, so they may in fact be cast in cylinders instead of sleeved??
Your best "bang for the buck" is to build a 6.0L because they're (obviously) the largest displacement (no replacement for displacement) and they have the best flowing heads (again, even better than LS1!) and they have the strength advantage of being cast iron (although LSx's have the WEIGHT advantage ).
That's as much as I know about them, other than to say pretty much everything is interchangable between all the engines!
I'm looking to get 400+hp plus like-stock drivability and fuel economy.
So I'm looking into a 6.0L with Z06 heads and a comparable cam with headers and exhaust.
jackpawt883
09-10-2015 08:53 PM
