99' Z28 miss and backfire on acceleration What Could I DO?
i have a 1999 Z28 LS1 it misses a little bit at idle but it misses really bad when you accelerate. I have changed pluges, Wires, cleaned MAF, new injectors, 2 new o2 sensors, new fuel pump. Still misses
MODS:Slp air lid, K&N, Headers, no cats
TROUBLE CODE: P0174
If you have any ideas please let me know Thans
TROUBLE CODE: P0174
Re: 99' Z28 miss and backfire on acceleration What Could I DO?
Do you have access to a scanner with "GM Enhanced Parameters"? It can recall the misfire count by individual cylinder, which may point you to the problem.
I would look for leaks and such on the passenger side of the intake (indicated by your code). Could be an intake gasket. The PCV come in on the passenger side up by the throttle body too, and those lines are known to crack. That misfire by cylinder could be key too.
-Geoff
-Geoff
def sounds like a intake leak... did you check that none of the new plugs had any cracks in the porcelin? I've seen how plugs nib can be thrown around during store transfers... also.. check for cracks in your coils too.
Deadbolt24
01-19-2015 01:29 PM
sleeperZ96BT
06-05-2005 09:33 PM
F(ast)-body
02-26-2003 09:05 AM
