A4 Transmission Fluid Change ?
Old 10-12-2002 | 07:28 AM
GatotsuZeroshiki's Avatar
I've heard that yanking the seal is a PITA. Is tehre a away around this? If i just wanted to change fldui but not filter woudl i still have to screw around with the seal?
Old 10-12-2002 | 09:41 AM
dohcsvt's Avatar
I never heard of having to change a seal when changing the fluid. You have to replace the pan gasket but that is all, and that is not hard. Also if you are changing the fluid, it is kinda useless unless you also change the filter.
PCLZ28
12-24-2015 05:19 PM
jmadoll
05-27-2015 07:13 PM
warmeck
03-16-2015 07:02 AM
jmadoll
03-03-2015 10:16 AM
jackpawt883
02-26-2015 09:04 PM
Quick Reply: A4 Transmission Fluid Change ?
