which air filter do you use?
Old 03-18-2004 | 04:04 PM
Amit's Avatar
im thinking of switching over from k&n to wix or fram.
how are these filters? im looking for somthing that seals very well.
Old 03-18-2004 | 04:38 PM
SFB767's Avatar
I use a Fram. Every time I check it, there's always a little dirt and small particles at the bottom of the airbox that never even made it through the filter. It's also still clean after two oil changes (when I replace it).
The paper filter is just more reliable and less risky to use than the K & N, which may give you 5 HP at the most. I'm not knocking K & N because of the latest GM warranty bulletin, I've always felt this way.
Old 03-18-2004 | 04:44 PM
psychocabbage's Avatar
AC DELCO is what I use
as for:
I lost 3rwhp with K&N and AMSOIL and NO Filter..
Consistantly and on seperate occasions.. I wont use it ever..
Its a panel vs a panel.. not a panel vs cone filter.. I think when people switch to a cone filter they have a better chance of getting more of an increase but panel vs panel paper out flows..
Old 03-18-2004 | 05:11 PM
stealth2's Avatar
None.
Old 03-18-2004 | 07:17 PM
Nsty98LS1's Avatar
when i bought my car it had a k&n. it's now rotting in the basement and now have fram in its place.
Old 03-19-2004 | 12:24 AM
RS Dragster's Avatar
I've got the Holley Powershot. I wanted something that would fit my MTI Clearlid, and some people complained about the K&N, so I got the Holley instead.
Old 03-19-2004 | 12:28 AM
Knowklew's Avatar
Fram paper filter.....i just checked it a few days ago....its still almost brand new and it has about 3000 miles on it.
Old 03-19-2004 | 12:34 AM
99blackSS's Avatar
Same here. My reason was I had a K&N on my 98 V6 (same air filter as LS1) and it had a gasket you had to put on and it didn't want to stay on after opening the lid a few times. The holley air filter doesn't require a gasket and is reusuable.
Old 03-19-2004 | 07:49 AM
Darth Xed's Avatar
Holley Powershot!
Old 03-19-2004 | 01:26 PM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
I too use the Holley Powershot, very nice fit.
SteveC
PCLZ28
12-24-2015 05:19 PM
Darth_tsunami
V6 Tech
09-18-2015 01:57 AM
Latronaxe
04-29-2015 08:25 AM
kksi
03-21-2015 09:03 PM
Jazsun
12-29-2014 12:14 PM
Quick Reply: which air filter do you use?
