Anyone found metal particles on their drain plug?
Old 02-21-2004 | 11:56 PM
Ron78Z&01SS's Avatar
I changed my oil the other day and found some metal on the magnetic tip of my drain plug. Just a little bit of mettalic grit, doesn't even cover the whole magnet. The only real piece was a thin sliver about 1/8" long.
It has about 18,000 miles on it, and from the service decal in the corner of the window the oil was last changed at a quick-lube type place.
Not sure if I should be worried or not.
What do you guys think?
Old 02-22-2004 | 12:07 AM
99blackSS's Avatar
I think that is why it's magnetic. I find little pieces on the plug too, I just wipe them off before I put the plug back in.
Old 02-23-2004 | 12:07 AM
Capn Pete's Avatar
It's pretty normal to find a little bit of metallic "fur" on the drain plug. I've found that the more miles on my engine, and every oil change, there has been less and less, but when the engine was newer, there would be a fair amount of those fine metal filings on the magnet and I think it's just from the engine breaking in and parts wearing slightly. IMO, nothing to worry about.
Magenta_Hearts
03-29-2017 08:54 PM
Magenta_Hearts
03-25-2015 10:24 AM
94Z28LS1toLT1
01-17-2015 08:29 PM
Sandersen511
01-13-2015 03:49 PM
HuJass
18
06-24-2002 09:19 PM
Quick Reply: Anyone found metal particles on their drain plug?
