Backfire at low throttle and WOT
Old 02-25-2006 | 05:27 PM
1LE4ME's Avatar
I'm still having problems after my header install. I fixed all of the leaks, and tried new O2 sensors. But my car is still backfiring at a low throttle for slow acceleration, and it backfires if I go to WOT. I'm still confused as to why it is doing this. I have triple checked what seems like everything on the car. Is it time that I just breakdown and get a tune? Would this really fix the problem? I still think it shouldn't be running this bad from a header install. What should I do?
Old 02-25-2006 | 09:19 PM
Kataklysm's Avatar
Re: Backfire at low throttle and WOT
I'm seeing you have a loudmouth on the car, that exhaust tends to pop which could be mistaken for a backfire, my old LT1 did it every time I let off the gas.
Old 02-25-2006 | 10:49 PM
ztwntyn8's Avatar
If you had the spark plug wires off during the instal, then I would go over the wiring to make sure that you don't have two of them crossed. The passenger side has gotten me a couple of times and it ran poorly and backfired. Take your time and hopefuly you'll have some luck!
Old 02-26-2006 | 12:56 PM
1LE4ME's Avatar
What do you mean have two of them crossed? Don't the powerpacks sit above the cylinder they are supposed to be hooked up to?
Chet1185
05-10-2015 09:24 AM
Noenav
04-30-2015 01:06 PM
Magenta_Hearts
03-22-2015 03:36 PM
captcorvette
03-07-2015 12:37 PM
bfmv13trivium
01-14-2015 09:57 AM
Quick Reply: Backfire at low throttle and WOT
