Bead Blasting Aluminum Cylinder Heads???
Old 04-08-2005 | 12:49 PM
BadgeZ28's Avatar
I picked up a used set of LS1 heads to modify. I am wondering if using a bead blaster to clean up the gasket surfaces and combustion chambers is a good or bad idea? Thanks
Old 04-08-2005 | 12:57 PM
ZeeDaddy's Avatar
Re: Bead Blasting Aluminum Cylinder Heads???
Bad idea. Clean them with lacquer thinner. If the surfaces have been badly mared you should get them resurfaced.
Old 04-08-2005 | 01:53 PM
MaxLean's Avatar
Bead blasting is done all the time to aluminum heads. Just don't hit any machined surfaces that aren't going to get re-machined. In other words, guides, valve seats, deck surface, etc. If your getting the heads resurfaced and the seats recut, then it doesn't matter. And be carefull to completely clean the heads afterwards.
10-31-2016 11:09 AM
oldschool
02-09-2016 09:21 PM
Chris Anderson
01-27-2015 08:30 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Elcojoe
11-17-2014 10:27 PM
Quick Reply: Bead Blasting Aluminum Cylinder Heads???
