Bigger fuel injectors...
Hey guys. How do bigger fuel injectors help exactly, are they really worth it? Current mods are in my sig, but I am going to be adding a supercharger and heads/cam combo eventually. When would you replace your fuel injectors, if at all? Thanks.
You dont need bigger injectors right now.
in order for you to run bigger injectors properly.. you need to have the computer programmed to take away fuel more or less..
adding fuel to sometthing that doesnt have enuff air to burn it all properly only hurts you.. gm sets these cars up to run rich from the factory anyways. thats why porting the maf or leaning them out some other way helps so much.
most head and cam setups dont need bigger injectors.. prolly a good idea with larger cubes, or heads cam and n20. or a blower.. etc
help that helps
help that helps
JasonD
08-23-2010 03:14 PM
