A/C not kicking on, what could it be?
Old 07-08-2002 | 07:51 PM
STS-Formula's Avatar
Post A/C not kicking on, what could it be?
I know the compressor isn't kicking on, I can't hear the clutch kicking out, it just blows air inside. Could it be a fuse or is there a switch that controls it?
Anyone dealt with this before?
STEVE
99 TA
MAC headers/ORP, Hooker catback,Whisper Lid, MAF ends, FTRA, K&N, BMR LCAs,EGR
mod,stock 2.73s
With just a K&N
299.3 RWHP
285.4 RWTQ
Old 07-08-2002 | 10:24 PM
Post
I just checked the fuse and it's OK.
Could it be the relay?
I will check it tommorow for low freon, does anybody know where the high pressure switch is?
STEVE
Old 07-09-2002 | 06:56 AM
Kwiksilverz28's Avatar
Post
Sounds like low freon. Check the low side, not the high side.
Old 07-09-2002 | 01:05 PM
unclejohn's Avatar
Talking
[B]I know the compressor isn't kicking on, I can't hear the clutch kicking out, it just blows air inside. Could it be a fuse or is there a switch that controls it?
STEVE
I don't remember what year your car was ,but try this: open the glove box and look for the A.C. wires that were pinched by the glove box. it only should take you three minutes. I forget what color the wire is but you should be able to figure it out. Hope this helps!!
Old 07-09-2002 | 10:40 PM
amood's Avatar
Post
Low freon!!! Almost a sure bet....if it were pinched wires you almost certainly would have at least some warning beforehand as I assume you HAD A/C and then lost it. The real funk will be where did you lose your cool (freon)? Hope it ain't at the evap. core.
Old 07-10-2002 | 04:28 PM
TA2001's Avatar
Post
here is ac info..
http://ls1info.com/article.php?sid=233
Aaront810
08-29-2020 09:34 PM
magman
04-15-2016 03:08 AM
93 RedBird
11-15-2015 08:24 AM
surreybrad
09-29-2015 09:00 PM
Z Power
09-19-2015 11:19 PM
Quick Reply: A/C not kicking on, what could it be?
