car wont start
Old 07-15-2005 | 03:41 PM
MarlboroMan's Avatar
car wont start
i got a 99 camaro z28 and i was filling up gas and car was running fine......went to turn it back on and it wouldnt turn over.....its not the battery and dont think its the starter....what could it be?
Old 07-15-2005 | 03:47 PM
themessageboard's Avatar
Re: car wont start
Could possibly be the fuel pump. Do you hear the fuel pump turn on?? Could just be the fuel pump relay. If its the fuel pump you can spray some starting fluid into the throttle body and it may start to turn over. Have you had any problems with the car starting in the past? If its been hard to start in the past those could be the warning signs. If not it could be a simple relay.
Old 07-15-2005 | 03:54 PM
Re: car wont start
if i let it sit for a few minutes it started twice and then the third time i tried it wouldnt start again it wont even turn over....?
Old 07-15-2005 | 05:07 PM
Greed4Speed's Avatar
Re: car wont start
Sounds like fuel pump getting hot. Do you run it below 1/4 tank often?
Old 07-15-2005 | 08:11 PM
angel71rs's Avatar
Re: car wont start
If it's not kicking over the motor at all, I would look at the neutral safety switch 1st if it's an automatic. Are all the battery/starter cables clean/tight?
Old 07-15-2005 | 09:50 PM
Re: car wont start
Hell, I missed the "won't turn over part." Ya, thats NOT fuel pump related. Guess I need to read better while I'm wasting time at work...
Mine got where it was cranky like that, and it was a dead cell.
Old 07-16-2005 | 01:25 AM
Re: car wont start
ok thanks guys- ill check that stuff out in the morning, and ill let you know how it turns out.. thanks a lot!
Old 07-16-2005 | 07:05 AM
350TPI5SPEED's Avatar
Re: car wont start
is there any way you can scan the computer? it might be the pass-key system (the little resistor in the key). one way to tell without scanning it, is to see if the security light flashes when you are trying to start it.
but first, do you have power in the car(lights, radio, etc.)?
Old 07-17-2005 | 04:13 AM
angel71rs's Avatar
Re: car wont start
Forgot to mention: a quick way to test NS switch: pop off the connector with heavy gage wires at the switch. Use a paper clip to bridge the connector wires. Insulate paper clip w/tape. Try turning it over. If it starts, replace ns switch. This trick saved me from a tow bill at my last job's parking lot when I had my 89 Formula.
Old 10-22-2007 | 08:41 AM
2nd2none's Avatar
Was this problem ever fixed, because I know have this problem. Mine is a 2002 M6 though.
Old 10-22-2007 | 11:21 AM
Sebastian's Avatar
check for corrosion on the terminals
Noenav
03-01-2019 07:38 AM
97SSdude
12-31-2014 07:43 PM
tds1213
11-27-2014 12:55 PM
USAirman93
11-24-2014 03:37 PM
Dave19yz28
01-26-2003 01:45 PM
Quick Reply: car wont start
