Clicking Engine Noise
Old 11-18-2004 | 05:57 PM
planters49's Avatar
Hello,
I have a 1998 Z28 with automatic transmission. The car has about 78,000 miles on it. Lately (around 70,000 miles) I have been hearing a clicking fluttering like sound coming from the engine when I press the gas pedal. After a couple of seconds the clicking noise goes away, but when I get back on the gas, it does it again. Also this problem only happens once the engine is warmed up. It's really noticeable when coming off a dead start like when taking off from a stoplight. Does anybody have any ideas as what is going on???
thanks
Old 11-18-2004 | 07:45 PM
Zitty'sZ's Avatar
Re: Clicking Engine Noise
The sounds you are hearing is most likely detonation in the combustion chambers of your engine,the usual cause for this is simply a poor or low octane fuel.You should only run premium gas in your Z ,if you are already using premium try another brand of gas,I have been using Shell V POWER with no problems.
Old 11-19-2004 | 08:23 AM
planters49's Avatar
I've already looked into the octan. I don't believe this is the problem. I did have to change one of the rocker arms at around 50,000 miles. Is it possible that another one has gone bad? I just changed the oil and I got no bearing needles out. (when the first rocker arm went bad,I got a bunch of needle bearings out of the oil.)
Old 11-19-2004 | 03:53 PM
BirchMan98z's Avatar
bent rod perhaps.
Old 11-19-2004 | 04:05 PM
Zitty'sZ's Avatar
If you are absolutely sure that it is not a fuel issue,you might look at your valve springs,from what I have read in magazines and what I been told by a GM master tech,the valve springs in the stock form are not very good.Just a guess though, but a place to start looking,GOOD LUCK!
Old 11-20-2004 | 11:22 PM
planters49's Avatar
Thanks for all the help, I'll look into the valve springs.
Dave19yz28
01-26-2003 01:45 PM
HuJass
08-29-2002 02:30 AM
HuJass
08-27-2002 09:58 PM
HuJass
08-27-2002 09:53 PM
HuJass
06-27-2002 11:04 PM
Quick Reply: Clicking Engine Noise
