Clutch Replacement Which Brand?
I don't drag race my 99 Z28 M6. I want a clutch better than stock. However, I don't want it to be hard to drive in traffic. I am considering a CENTERFORCE regular or a CENTERFORCE dual friction.
Will the dual friction be too hard to drive in traffic? I also tow my small boat with the car too. Other brands to consider that will meet my needs? Thanks.
DO NOT BUY CENTERFORCE, i can not stress enough DO NOT BUY CENTERFORCE, THEY SUCK if you do make the worst descision of your life and buy the dual friction, it has a hard peddel. if you dont race and have a stock motor, keep the stock clutch, or get the z06 clutch. the centerforce clutch has had a lot of problems with breaking into pieces NO LIE.
Depends on how much HP you plan on having in your car. If you are keeping your car stock just get the 2002 Z06 clutch and updated slave cylinder.
If you plan on adding some decent hp(~380rwhp) then get a Cartek clutch www.cartek.net or a Star Spec Stage 3 clutch with new hydrolics. Don't forget to replace the pilot and throw out bearings while doing this.
