Cost 'O 427
Cost 'O 427
What's the cost to turn the LS1 into a 427? I know John L. wants 30k for it but that is mostly labor costs probably. I just want parts and how much it should cost to bore it professionally.
check out, www.motorsporttech.com i think they sell stroker kits. Most of the performance sites do. As for the bore, aluminum blocks are damn expensive to have bored, thats if you can. Call around to some local performance shops in you area, they should know.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Soon to be:
I'm pretty sure that the aluminum blocks actually use pressed-in steel sleeves for the cylinders, so whether or not you can have the sleeves bored, I'm not sure?? (sorry ) Maybe you can get the block re-sleeved with larger bored sleeves though?? Again, I'm not too sure, but that's something to look into.
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - Pics
No, Lingenfelter nor anyone else turns your LS1 into a 427. They prepare a new block for you.
The "resleeving" that MTI does, along with their 4" stroker kit, will get you a 422. Not quite the same thing.
And yes it is expensive. Very.
1983 Monte Carlo, 307 Stroker, TH350, 3.73 10-Bolt - SOLD 8/19/02
Future F-Body Owner
Future F-Body Owner
09-11-2015 09:44 AM
gonzo275rltw
3rd Gen / L98 Engine Tech
09-07-2015 04:46 PM
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
