Cutting out two cylinders?
Ok, I remember back when the 98 Camaro and Firebird Came out with the LS1 motor. Now I also remember reading something about the ability to actually shut off 2 cylinders or something like that. It was something to do incase your teenager or perhaps a valet parker got in your car. Thinking they would hotrod it. Some kind of switch that would disable 2 cylinders. Which would reduce horsepower and enable better gas mileage on the highways. Am I just crazy? Or did I really read this somewheres? Was it an option on 98 up Camaros and Formalas?
No such thing
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
DaveD
1998 WS6 #207
1998 Regal GS
-It Has Boost
I think I know what you are talking about.
Gm has experimented in the past with "displacement on demand". they had it on caddillacs in the eighties and it was not sucessful. There was no switch, the car would shut down 2 or 4 cylinders if they werent needed. Under a load, all eight would be used, but going down the highway under a light load, only 4 or 6 would be used. The LS1 never had this. I have heard that GM is again trying to make this work, it is supposedly a much smoother transition when cylinders are activated or deactivated.
That would suck...think about your expensive exhaust system you put on your car. As soon as those cylinders shut off, your car loses that muscular rumble and sounds like a 6 banger.
1983 Monte Carlo, 307 Stroker, TH350, 3.73 10-Bolt - SOLD 8/19/02
Future F-Body Owner
Future F-Body Owner
I've never heard of it in the LS1. I heard the ZR1 had this. It was either a cylinder shutdown or a spped governor. Chevy is expirementing again with the new Vette engine. This thing has electrically actuated valves. It would close both valves and kill fuel and spark. Rumor has it placed at over 30 mpg and 500+ hp.
2000 Camaro Z28 Monterey Maroon Metallic, A4 ,leather, 323 posi, Monsoon w/CD, T-tops, K&N
You can't actually turn them off but the pcm does fire every other cylinder if the car overheats to keep it from damaging the motor.
Fred
Pewter 2001 TA WS6 6spd (stock)
Silver 1996 TA WS6,A4,GU5,Powerdyne SC 4.5#,Edelbrock headers,Random Tech dual-cat y-pipe,SLP 2500 stall TC,TransGo shift kit,B&M 24,000 trans cooler,HPP+ w/scanner,BBK 52mm TB,GMS MAF,RKSport 5-way Adj.shock system,Jamex lowering springs,Lakewood Adj.PHR&LCA's,160 stat,Flowmaster 3" catback,K&N,Accel 300+ ignition&wires,LT4KM,NGK TR6,o2 sims,!TB
Fred
<font face="Verdana, Arial" size="2">Originally posted by ZZed:
I've never heard of it in the LS1. I heard the ZR1 had this. It was either a cylinder shutdown or a spped governor. </font>
White 1990 LX Hatch 5.0 Vortech S trim, fuel system, blah blah blah..
Black 1995 Honda Civic Ex Daily driver, 36 mpg
bigredjim.corral.net: now, banner free!
sleeperZ96BT
09-09-2015 08:28 AM
08-07-2015 08:52 AM
NewsBot
07-08-2015 06:47 PM
