Electrical Problem: Any Suggestions?
A few weeks ago I put a nitrous setup on my car, NX wet kit. Yesterday I bought a new switch panel for it, and this morning I set about wiring it and a new bottle opener in. I disconnected the battery, and ran all my wiring and got everything connected.
Satisfied I had everything wired correctly, I connected the battery and began checking switch functions. They all seemed to be working correctly, so (without bottle hooked up or engine running) I left the ignition key in the run position and made contact with the WOT switch to check that both solenoids were working correctly. One loud click and that's it folks.
Now when I turn the key to the run position I can hear the fuel pump, and the radio will come on. It will not crank, and there's no power to the dash gauges. I have checked any fuse that even remotely looks like it may be labeled for an engine function, checked to make sure the battery connections are good.
Any further suggestions?? FWIW it's a '01 Z
