Engine Terms
Engine Terms
You guys always lose me at certain words. Could ya help me out and define these for me plzzzzzzzzzzzzzz:
cam (or cam kit)
blower
stroker (or stroker kit)
wtf are those and how do they work :>
cam (or cam kit)
blower
Re: Engine Terms
cam (or cam kit)
blower
cam (or cam kit)
blower
blower = basically a supercharger. typically uses a turbine driven by a belt to force air into the engine at different compession levels (psi).
stroker = usually refers to getting a new crankshaft. the crankshaft increases the stroke of the motor (how far down the pistons move) which therefore increases the displacement of the engine (ie: 346ci is a stock LS1 displacement, most typical strokers increase it to 383ci), hence making more power.
hope that helps a bit.
errr? Thank you for NOT being a ****...jeez, where else would I post this? It's about the LS1 engine technically. Grade school? Sorry, I wasn't worried about cars, I was worried about getting out of grade school.
GrdLockV6, thx for the help
Oh, also, check out www.howstuffworks.com
Go to the automobile section and they have very nice how this and that works with nice flash animations and everything that will definitely teach you a lot about how an engine works.
NewsBot
02-06-2015 05:00 PM
NewsBot
01-29-2015 07:10 PM
NewsBot
01-21-2015 06:10 PM
NewsBot
01-11-2015 06:10 PM
NewsBot
12-28-2014 06:20 PM
