explanation needed-idle quality
Old 02-03-2007 | 10:14 PM
maro z28's Avatar
Patrick G just explained that idle quality and lope are a result of overlap. More overlap, choppier idle. I thought idle quality was a result of EVO. I.E. an earlier EVO would result in a choppier idle b/c the sound of combustion was reverberated past the open exhaust valve and less muffling of its sound. How does overlap effect idle quality? Explanations appreciated. Thank you.
Old 02-04-2007 | 02:00 AM
Mean Green Z28's Avatar
Lower LSA (more overlap), nice lope at idle 'cos the car is basically trying to DIE at the lower RPM
Old 02-05-2007 | 01:16 PM
RE AND CHERYL's Avatar
The more overlap the cam has the worse the cylinder scavanging is at low RPM and the more exhaust is left in the cylinder. As Mean Green said. It's barely running and wants to die. This is why engines with real big cams have to have a higher idle.
Re'
Old 02-05-2007 | 03:56 PM
maro z28's Avatar
That explains it...thanks
Hal Fisher
09-30-2015 09:03 PM
NewsBot
09-30-2015 04:20 PM
CARiD
09-30-2015 05:44 AM
NewsBot
09-15-2015 11:53 AM
NewsBot
09-14-2015 02:02 AM
Quick Reply: explanation needed-idle quality
