gauge faces
I installed the overlays from HPAParts.com. You do not need to remove the needles with this overlay. It takes about 30-45 minutes to remove the cluster on your first attempt. If you lower the steering column (remove two bolts under the dash), it will be MUCH easier to remove the cluster.
You must take your time installing the overlays, but they look great.
MVS
MVS
RX Speed Works
09-11-2015 03:31 PM
jackpawt883
09-10-2015 08:53 PM
