General question about the LS1
Old 12-02-2005 | 08:53 PM
  #16
cpope's Avatar
Re: General question about the LS1
I put the lt1 out of my wrecked 97 bird into my 92 s10 after it finally broke a timing chain at 260,000+ miles. It would have only cost me about $20 and 2 hours to fix it. I never did anything to the motor other than sometimes change the oil (never @ 3000, usually @ 5-10000). I BEAT THE HELL OUT OF THAT MOTOR EVERY DAY.
My wife's 96 mazda 626 has over 200k on the clock and is still running strong. It has a good power to weight ratio (equiped with the 2.5l v6).
Point: It is a matter of preference not reliability.
Old 12-03-2005 | 04:38 PM
  #17
butterbar's Avatar
Originally Posted by samualt
And for God's sake don't buy anything from a store that won't say "Merry Christmas".
agreed!
Old 12-04-2005 | 12:07 PM
  #18
got_z28's Avatar
I’ve had my 02 Z28 since 10/12/01 the M6 Trans failed at 1200 miles it now has 53000 miles on it no major issues. The only yearly expense I spend is on Transmission mounts, Sway bar bushing, and the Z rated tires I have used Royal Purple 5w-30 since the 1st oil change.
Old 12-04-2005 | 01:45 PM
  #19
CajunCC's Avatar
The KL is a fantastic motor. I've seen them well over 200k miles. And the few known problems they do have are mostly cosmetic, like HLA tap and friction gear noise. A good kerosene flush will clean out the HLAs to stop the tick, and a new friction gear spring and nut will set you back $20 at a dealer and will fix the issue for good (redesigned parts). It's a pain to install, because it requires pulling camshafts, but once you do both of those things, you're back to having a whisper-quiet KL again.
BTW, if you ever have any issues with that car, hit me up with a PM or check out http://www.probetalk.com/forums . The 93-97 Ford Probe and Mazda MX-6 use the same drivetrain and major chassis parts as your 626 and there are a LOT of very knowledgeable people on probetalk.
Old 12-05-2005 | 09:31 PM
  #20
RiceNoMore's Avatar
Thanks to all for your input. He is still hesitant on the idea, but he has faced the facts that I will be paying for it, not him. And I'm hell bent on buying the 98 Z28 i found. It should be a good buy, 6MT and only 47,769 miles.
Old 12-05-2005 | 09:55 PM
  #21
SFB767's Avatar
There you go, that's what counts.
I bought mine when I was 21 and finishing college and my Dad's reason for not wanting me to get one was because he said the new Camaro is a girl's car.
Old 12-05-2005 | 10:10 PM
  #22
TransAmAbe's Avatar
Anthony, I'm gonna kill your dad. I'm sure you'll understand.
Feffman
10-09-2015 06:42 AM
ChrisFrez
01-18-2015 09:05 AM
jayblev95
Track Kill Stories
01-15-2015 08:48 AM
ChrisFrez
11-23-2014 11:33 AM
guionM
14
06-19-2002 09:30 AM
