guys with 99 to 00 Ls1 camaros and trans am what are u running stock in the 1/4 mile?
just curious what times u guys have with your stock or slightly modified LS1 with exhaust and air lid?
I've seen 99's running 13.4's~13.8's (stock) depending on the model (conv. f-bodies tend to be a little slower). With a lid & catback, I went 13.6 (short shifting @ 5500rpm + 95 deg. humid weather) in Englishtown a few years ago. My guess is there was at least another .2 seconds I could have shaved off the run given a better launch, better weather & 6000rpm shifts. But, I had to drive the car home...so I didn't wanna risk breakin' nothing.
Check out this time slip...
http://www.mustangmods.com/data/5431/dsc01697.jpg
My dad's car is a 2000 SS Convertible with a Lid and the SLP CME factory exhaust. Being that his car is a convertible, I'm pretty sure it weighs in about 200 pounds more than you're average non-convertible LS1 F-body.
Anyways, that was his best run...he is generally in the low 13.3's.
-Dan
-Dan
i ran 13.544 @ 104.87 stock EVERYTHING cept tires (nitto 245/50/16) and clutch is slipping just a little... slipped a little in 1st,and a TINY bit of 2nd
r/t .074
60' 2.102
330 5.869
1/8 8.862
MPH 82.65
1000' 11.386
1/4 13.544
MPH 104.87
NPR 1/7/04 9:46pm
cory
r/t .074
60' 2.102
330 5.869
1/8 8.862
MPH 82.65
1000' 11.386
1/4 13.544
MPH 104.87
NPR 1/7/04 9:46pm
cory
13.12 @ 106 for me Bone stock. I ran at Rockingham Dragway in NC on a perfect friday night with crappy street tires.
My 1/8th mile time was a 8.59 @ 83 mph.
I now have a lot more mods , but a worn out clutch so no times as of yet on my new setup.
Well, this probably won't help you much since I've only been on a 1/8 track but I ran 9.008 at 80 mph with a 2.1 60 ft, and that was when my car was stock. I haven't been to the track since I got my lid, or shift kit installed.
See sig. Only "mod" is a K & N air filter. All else is stock, even tires. Elevation is around 630'. Temp was high 70's. Slightly humid, but not enough to choke you. Race weight was 3620. Shallow stage. Trans left in D. It is an NHRA track with excellent prep. No noticable wind. Temperature and humidity affect these cars. On a hot and humid day, I have trouble breaking into the 13.50s. Traps are between 101 and 104.
