Hatchback sqeek!
There are 2 different fixes for this.The first is to pop your hatch and on either side you will see 2 little rubber "bumpers".These are just screwed in to the hatch.Unscrew them a couple of turns and then close the hatch.This should put more pressure on the hatch release (which is what's squeaking) and stop the noise.If this doesn't work,then the 100% sure-fire way to stop the squeaking is with the ghetto fix.Simply pop your hatch,take some black electrical tape and wrap it around the little "U" that goes into the latch.Wrap a couple of layers of tape and it will keep the metal pieces from rubbing on each other and get rid of the squeak.Good luck.
Kevin
Kevin
really? thanks man... i will look as soon as i get my car back from chevy (which they had 3 weeks) because my tranny is a peace of freakin crap!!!!
anyone know how to fix the hydraulic from sqeaking, im pretty sure that squeaks also.
Tell me more, tell me more ...
I have a cold weather squeak (below 65 degrees) that sounds like a damn bird loose in the cockpit !!
Is that the type of squeak you are referring to ?
If so, I may take that "ghetto" route & see if it quiets down.
Thanks for the info !
Britt
Britt
WestCoast96Z28
06-28-2004 12:38 AM
WERM
61
07-26-2003 08:52 AM
johnsocal
34
06-03-2003 01:36 AM
