head bolts sealer or not (ls1)
Old 01-26-2003 | 09:59 PM
STAGE274V6's Avatar
Guys do any of the head bolts need sealer or not . The car is a 2000 Z28 with an ARE 385 and MTI heads . TIA
Old 01-26-2003 | 10:25 PM
Dr.Mudge's Avatar
I'm going to guess yes, some of the bolts run through coolant passages on cars, if this is true on your car you should use it.
Old 01-26-2003 | 10:30 PM
99huggerorangeZ's Avatar
Question
i am building a SB1 out of a 350 86-99 block and i am wondering what bolts i should use thread sealer on?
i am using ARP head studs and main studs other that that the rest are ARP bolts
Old 01-27-2003 | 08:19 AM
kmook's Avatar
Advanced Tech Moderator
Welcome to the board,
A question like yours would be better suited for a tech forum in your case LS1 Tech. I'll move it there for you.
Thanks bud.
Old 01-27-2003 | 11:15 AM
Lance Melnek's Avatar
Consult a shop manual to ensure you do it right...I haven't torn down an ls1 but numerous chev sb's. I use loctite 567 on the bolts..all of them.
10-31-2016 11:09 AM
maybe2fast
03-16-2015 09:45 AM
HectorM52
Parts Wanted
02-11-2015 09:33 AM
HectorM52
Parts Wanted
01-10-2015 09:01 PM
Quick Reply: head bolts sealer or not (ls1)
