Heads and Cam ????
Old 07-10-2002 | 10:05 PM
Bill'sWS6's Avatar
Question Heads and Cam ????
Does anyone make a good head and cam package that won't break the bank and would be worth at least 75 RWHP?
Thanks,
Thanks,
Bill
Click here for my best strip time!
98 WS6, Nitto 315/35/17's,MAC Headders and Off Road Y-Pipe, Flowmaster American Thunder Catback, Vig 3200 Stall, TransGo Shift Kit, MTI Clear Lid, K&N Filter, TR55 NGK's, Taylor 8mm wires, EGR MOD & Other Free Mods. 12.84 @ 104.15 MPH 60ft 1.73.
Old 07-10-2002 | 10:38 PM
supersp0rt's Avatar
Post
haha, youre joking right? i doubt youll find much cheaper that about 3-4k. highly doubt it.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
Old 07-11-2002 | 07:44 AM
PhantomTA's Avatar
Moderator
Post
Still have heads for sell Bill
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
Old 07-11-2002 | 09:33 AM
Chrisdude's Avatar
Post
How much does it cost to have a heads/cam package installed?
Old 07-11-2002 | 12:14 PM
redz_02's Avatar
Post
You could always get a set off ebay and port them yourself
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
-Borla (the expensive cut-out)
-Wisperlid W/K&N
-FRA
-Cags eliminator
-Strange 4.10's
-G2 Rear Girdle
-Valv. Synthetic 10W-30
-Redline gear oil
-Fat hurst shift ****
-Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtr 900.2, Kicker 12L7 in a milhouse, Focal polykev K2's.
Old 07-17-2002 | 10:11 AM
ScLeCo's Avatar
Post
Just depends on what you mean by "break the bank" CNC / Thunder Racing STAGE 2 LS1 Cylinder Heads, 2.08" Intake, 1.60" Exhaust Valves, assembled with dual coil valve springs and titanium retainers ($500 CORE CHARGE)
$2,495.00
Thunder Racing LS1 Cam Swap Package Includes:
- Your Choice of Thunder Racing Custom Grind Camshaft
- Comp Cams 26918 Valve Springs
- Comp Cams 772 Titanium Retainers ($100 Additional)
- Thunder Racing Stock Length Pushrods (7.400)
- Cam Swap Gasket Kit (Specify Year of Car)
Cam 99-230/224-11199-227/224-11499-224/227-11499-224/224-11299-224/224-11499-220/220-11299-220/220-114 Retainers None (Re-use your stock retainers)Titanium Retainers - Add $100.00 Year 1997-19981999-20002001-2002 $699.99
looking at about $800.00 for instal.
Old 07-17-2002 | 10:14 AM
ScLeCo's Avatar
Post
$2,495.00
TR 224/112LSA cam,CNC Heads,Volant induction,BBK throttle body,SLP stage 1 suspension, powerslut rotors, mosser 12 bolt, SPEC stage 3 carbon fiber clutch, ASP pulleys,Lingenfelter alm driveshaft, BMR sway bars, lower controll arms, panhard rod, track pak, taylor wires, NGK plugs, B&M ripper shifter, ECT...
10-31-2016 11:09 AM
StansZ28
02-19-2015 07:39 AM
kaoticcamaross
02-17-2015 03:13 PM
birdblack
12-30-2014 06:59 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: Heads and Cam ????
