Help
Help
http://i14.photobucket.com/albums/a...y8/P1010497.jpg
ok well the first problem is my drivers side running light. it went out a month ago and i changed the bulb and it was fine till now. as you can see the connector has corroded..Where can i buy a new connector? and what is all needed to change it out? splicing etc.... anyone got a write up?
http://i14.photobucket.com/albums/a...y8/P1010498.jpg
http://i14.photobucket.com/albums/a...y8/P1010501.jpg
http://i14.photobucket.com/albums/a...y8/P1010500.jpg
the other pics are pics of a leak but im not sure where it is coming from? seems like the rear main? where the engine connects to the trans? what does it look like to you?
__________________
__________________
