help, can't get pulley off.
Old 01-13-2008 | 06:29 PM
camz28aro's Avatar
I have an auto ls1 camaro and i just took the starter off and can't get the flywheel to stop spinning with the screwdriver wedged. How did you guys do it? What did you use to wedge it ect.
Old 01-13-2008 | 10:37 PM
Kraest's Avatar
Retired
The crank pulley?
It takes alot of elbow grease and a 2' breaker bar to do it by hand
Old 01-13-2008 | 10:45 PM
camz28aro's Avatar
I just tried again before you posted and just took that plastic cover that covers the flywheel where the starter goes and got good leverage with the screwdriver against the bellhousing but then I was nearly about to crack the huge screwdriver and the whole engine and tranny was moving.I was using a 3 foot breaker bar. I'll just bring it somewhere cause its all back togethor now. You think they'll rape me moneywise?
Old 01-13-2008 | 10:55 PM
Kraest's Avatar
Retired
The whole engine/tranny might move a little. It's in there RIDICULOUSLY hard.
See if the starter is up to the job. Don't forget to pull the plug wires first Be careful as I've never tried it this way on the LS1.
Old 01-13-2008 | 10:57 PM
Kraest's Avatar
Retired
You ARE turning it the correct way, right?
Old 01-13-2008 | 11:06 PM
Kraest's Avatar
Retired
Are you using this article?
http://www.ls1howto.com/index.php?article=23
Old 01-15-2008 | 11:20 AM
Marc 85Z28's Avatar
For what the shop is going to charge you could buy an impact gun, socket, and rent a compressor. Removing that bolt manually is a huge PITA on an automatic car. The impact is very useful here, and in many other repairs
Old 01-15-2008 | 01:21 PM
hagerbump's Avatar
Try talking to it a little nicer and maybe dinner and a movie. LOL
I just could not resist.
AviatorDave
12-19-2016 06:35 PM
RUENUF
03-13-2016 03:37 PM
PopoFormula
10-12-2015 04:19 PM
alliance12364
09-23-2015 12:40 PM
Matt Dreessen
09-09-2015 09:58 PM
Quick Reply: help, can't get pulley off.
