help with serpentine belt tensioner...
Old 08-07-2002 | 05:53 PM
94 green drop top's Avatar
Post help with serpentine belt tensioner...
i was just replacing my belt when i noticed the housing for the tensioner had part of the casting on the side broken off, and it would not tighten anymore. removed it from the block, took it apart, and there were some broken plastic pieces in among the spring, preventing it from allowing the spring to fully tighten the belt. removed the pieces, put it back together, and reinstalled it. belt is tight now, and works with ac on as well. however, it seems that the pulley on the tensioner (which should be able to move, if you were pulling/pushin on it to change the belt) is moving up and down just a little, within the 2 marks cast into the housing. my question is, how much vibrating is ok, if any at all? is it supposed to be rock solid? basically im trying to figure out whether this will work as a permanent fix of if i need to get a new tensioner assembly (minus the pulley).
thanks guys for your help.
Old 08-08-2002 | 12:22 PM
Post
ttt
also, anyone know where i can get one cheap (ie, under $40)
Old 08-08-2002 | 04:11 PM
nikkev's Avatar
Cool
<font face="Verdana, Arial" size="2">Originally posted by 94 green drop top:
ttt
</font>
I paid $15 at Autozone for one on my '95 3.4 V6.Should be about the same.
Kevin
95blkss
09-22-2015 03:18 PM
rideordie
09-07-2015 08:22 AM
WPHIG2
08-27-2015 06:37 AM
john henry
08-14-2015 08:33 AM
john henry
Classic Engine Tech
08-14-2015 08:33 AM
Quick Reply: help with serpentine belt tensioner...
