How to change DRL?
Old 02-27-2003 | 02:14 PM
DaveGrun's Avatar
How to change DRL?
One of my DRL's is burnt out, and that was what was causing my turn signal to not blink. How do i take the DRL cover off to get to the bulb? I dont want to crack it or anything. ALSO what bulbs do they use? Thanks.
Old 02-27-2003 | 04:44 PM
DougS's Avatar
You don't take the cover off. If you lie down and look under the car by that light, you will see a plastic flap that is held closed by a couple of bolts. Take these out, and open the flap. You will then be able to reach up and take the bulb out from behind. All you have to do is twist it. I don't remember the part number for the bulb off the top of my head, but you can get it at any parts store for a couple of bucks.
jayblev95
06-07-2015 04:04 PM
mdenz3
05-22-2015 09:25 AM
05-01-2015 01:14 PM
NewsBot
01-21-2015 06:10 PM
blac94Z
01-16-2015 11:03 PM
Quick Reply: How to change DRL?
