How easy is it to replace the cam?
#16
Originally posted by CobraKilla
Its not that easy...Your forgetting the differneces like Intake manifold, air ducts, heads, exhust manifolds, exhuaust as far as the engine of a LS6 vs an LS1...Also why spend all the money to use the Z06 stuff when you could get much better power from other cams and headers etc etc...
#17
I agree it's a difficult task and very time consuming, BUT if you have LOTS of time and follow good LS1 CAM install instructions (they're posted on many LS1 websites) you can do it. I'm just a weekend mechanic, work 50 hours per week, but I was able to do it. Then again, my Camaro is just a toy that I don't need for daily transportation. If yours is a daily driver....forget it. Also, if you're going to swap cams you'll be much happier if you can swap heads too...or at least have your originals professionally ported....makes a BIG difference. To get the most out of your cam swap you'll need to have your computer reprogrammed. I had Ed Wright do mine, as usual, he did an excellent job. So what's the pay off with heads/cam/pcm/hdrs? All I can say is.....WOW man! I couldn't believe the difference. I have so much tire spin through most of my gears that I'll be going through two sets of tires per year....and that's with an automatic. I couldn't be happier
#18
Originally posted by martinss01
well, thats actually one of the questions were looking for answers to . what are the advantages and disadvantages to your a-typical cam packages and why. why, in your opinion, is the ls6 z06 whatever package not worth the money/inferior to other cams? assume your talking to an idiot .
#19
Wait, wait, wait!! Cobraklilla, yer freind has long tubes and a TH224 with a 112 LSA in Cali!?!? I thought the biggest you can really go on a cam in CA is proly around a TR220 with a 114LSA and still pass a sniffer and anythinig bigger than certified shorty headers are illegal and theyll nail you for em? Please tell me if I'm wrong (and I hope that I am) because if so I got to really change some things on my mod list. Also, what about heads? what is the rules with those. Like was said above, assume I am an idiot and know nothing about CA smog laws.
#20
I'll let you know when I get my custom grind Comp cam installed. I think the haardest part is going to be changing the springs and dealing with the retainers and locks!
Other than that it's just time consuming. And I'll need to rent a puller, and valve spring compresser, and buy/rent AC recharger.
Should be fun though.....
#21
#22
#23
10-31-2016 11:09 AM
