How hard is it to change your gear? I have 4.10s and want to go with 3.73's.
![Post](https://www.camaroz28.com/forums/images/icons/icon1.gif)
Whats involved in doing the change? The prev. owner did the gear swap before I bought the car, so I don't know...
I have 4.10s in my '98 Z, with an auto. Its also most tooooo much. I'm currenly re-doing the suspension, but I still can't hook up from a roll. I'd like to be able to get on my with out having to wait til mid 2nd gear to kick in.
Its fun for doing burn outs, but tire smoke doesn't win races.
I'm also worried about my 10 bolt. I don't want to blow it up. I will be doing a T/A rear-end cover (girdle) next weekend, and I want to know how hard it would be to change the gears.
See my sig for all the work I've done to try and hook up....none of it has helped.
Milo
CAR:
Silver '98 Camaro Z28 | Auto | Hard Top
ENGINE MODS:
HPP+ | 180* Thermostat | Fast Toys Ram Air | Whisper Lid | K&N Filter | MSD 8MM Wires | NGK55 Spark Plugs | '98 SS Single 3" Outlet Exhaust | ! Air Conditioning | ! Cruise Control
SUSPENSION MODS (all done in red):
4.10 Gears | MAC Panhard Rod | MAC Lower Control Arms | T Byrne Sub-Frame Connectors | Eibach Lowering Springs | KYB AGX 8 Way Adj. Shocks | BMR Relocation Brackets | BMR Strut Tower Brace
MISC. MODS:
! CAT | ! Front Steel Bumper | Clear Turn Signals | Front and Rear Blackouts.
Milo
CAR:
ENGINE MODS:
MISC. MODS:
First of all I would go with the 3.42 gear. I had a 94 Z28 and I put 3.73 gears in it and the problem I had was in th 1/4 mile right before the traps it would shift into overdrive. You do not want an automatic going into overdrive in the 1/4 mile. I ended up putting the 3.23 gears back in and I got rearended before I took it back to the track. I now have a 99SS with 3.23 gears and it is hard to get traction with them but I did manage a 13.65 on a 90 degree day. As far as changing the gears unless you have alot of mechanical experience, extra shimms, micrometer, and a dial indicator I would not attempt it. You can do the way alot of people do and just take it apart use the same shimms and crush sleeve and simply install the new pinion and ring without proper setup. If you do this it will whine and you are flirting with disaster. Once a gear is improperly installed and whines it will always whine even if reinstalled by a professional. The only reason I did my own is because I have seen th guy who does mine do about 10 of them but I will not do another.
Milo,
Changing the ring and pinion takes a bit of work. Something I have not done yet. I have blown my posi and replaced it, reusing the stock 3.42 ring on it. I reused the shims and so far no gear whine. The difference there is that I did not pull out the pinion gear which is where most of the work is.
If you want my 3.42 ring and pinion gears (you can reuse your posi or get an Eaton or a Auburn instead) let me know. That will take a little more than a trip to McDonalds for you though!
If you're going to swap out the gears, have one of the local shops do it for you. We can help you find one, Dreamer1q has some great connections and I know of a few places as well.
You're running a 4.10 in an auto? That's just sick! Hell I'm only upgrading to a 3.73 in my M6.
Grand Rapids, MI
2002 WS6
http://www.sigma-epsilon.org/steve
stevedertien@attbi.com
Whisper Lid, Grotyohann Headers and Y-pipe, Corsa Exhaust, BMR SFC's, McLeod Single Disk, Spohn Torque Arm, LCA and Panhard Rod and much more to come
Grand Rapids, MI
2002 WS6
<font face="Verdana, Arial" size="2">Originally posted by derty:
Milo,
</font>
Milo,
</font>
After my insurance got canceled, I have to find a new carrier, some pleaces are asking up to $500 dollars......this hurts the wallet. I won't be able to do the gears, just asking about it. Trust me, a job like would be worth more then Micky D's.
brndn - thank you for the advice, and explaining the proccess to me
![](http://web.camaross.com/bb/smile.gif)
First off, for an A4 4.10s are way to much gear ... unless you are going with primarly a strip set up and a high end cam that's pushing your power band higher into the RPM range.
For an auto 3.73s are a good set up, just make sure you stay in D, so you don't shift into OD ... you'll be crossing the traps right around 5700-5900 rpm. Depending upon what your MPH is at that point and where your shift points are, you could find yourself shifting into OD.
As far as blowing off first gear on the street ... that's going to happen, even on stock gears, particularly on street tires. You'll just have to learn to feather your launch and tires such as Nitto DRs will help more than anything.
Also what do you have those AGXs set at? For drag racing you want the fronts set at 1 and the backs at least to 6 or 7 - I actually trick the set up and set the rear right to 8 and the rear left to 5 or 6 depending upon track conditions.
Last, unless you have a lot of mechanical acum, I would recommend finding a good shop to do your gear swap. You're also going have to find out how the previous owner calibrated the gear swap ... Because you're going have to recalibrate, if he did something like the SLP plug in, you should be OK. But if he flashed the computer, you really need the original program, since you have no way of knowing what else has been changed.
Good Luck
'01 Mystic Teal Z28
A4/3.73
Mods List Here
12.12/112.81/1.70 60'
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
"To play it safe is not to play"
[This message has been edited by V6toZ28 (edited August 16, 2002).]
Good Luck
'01 Mystic Teal Z28
A4/3.73
Mods List Here
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
![Thumbs up](https://www.camaroz28.com/forums/images/icons/icon14.gif)
<font face="Verdana, Arial" size="2">Originally posted by V6toZ28:
First off, for an A4 4.10s are way to much gear ... unless you are going with primarly a strip set up and a high end cam that's pushing your power band higher into the RPM range. </font>
No Cam as of yet...or as far as I know. There were, and still are a lot of unknowns with this car. I bought it from a whole sale dealer. He knew nothing about the car.
I just know when I drove it home, I learned it had a different gear in it. I jacked up the rear ties and spun the tire once and counted how many times the drive shaft spun over. It was just over 4 = 4.10 gears.
For an auto 3.73s are a good set up, just make sure you stay in D, so you don't shift into OD ... you'll be crossing the traps right around 5700-5900 rpm. Depending upon what your MPH is at that point and where your shift points are, you could find yourself shifting into OD.</font>
I have a HPP, and can play with the shift points along with the rev limiter. I think with some track time, I should be able to get it to shift right.
As far as blowing off first gear on the street ... that's going to happen, even on stock gears, particularly on street tires. You'll just have to learn to feather your launch and tires such as Nitto DRs will help more than anything. </font>
Street Slicks are on my list.....
I just want to be careful not blow my 10-bolt. I think with just street slicks, not real slicks, I should be okay.
Also what do you have those AGXs set at? For drag racing you want the fronts set at 1 and the backs at least to 6 or 7 - I actually trick the set up and set the rear right to 8 and the rear left to 5 or 6 depending upon track conditions.</font>
THANK YOU, THANK YOU, THANK YOU! I have asked everyone what they should be set at, or at least an idea...no body knew. Right now they are set at like 6 in the front, and 8 in the back. I'll try your combo and see how it helps me from a stop.
Last, unless you have a lot of mechanical acum, I would recommend finding a good shop to do your gear swap. You're also going have to find out how the previous owner calibrated the gear swap ... Because you're going have to recalibrate, if he did something like the SLP plug in, you should be OK. But if he flashed the computer, you really need the original program, since you have no way of knowing what else has been changed.</font>
As I said before, I have a HPP, so doing the gears wouldn't be an issue. Also, like I mentioned before, the gears were done before I bought the car, so I have no idea what he did, or what needs to be done.
Good Luck</font>
Good Luck</font>
![](http://web.camaross.com/bb/biggrin.gif)
Milo
</font>
</font>
![](http://web.camaross.com/bb/confused.gif)
<font face="Verdana, Arial" size="2">Originally posted by Z-Fbody:
Those are just the track settings right?
What do you normally have them set at?</font>
Basically on the AGXs setting 1 is approximately equivalent to stock OEM. Since you want to release, you need a softer setting than stock up front. So for now I just left the stock shock up front, since there is nothing to be gained with the KYBs - eventually I'll probably get the HALs.
In the rear the opposite is true. You want the rear to be stiff and not squat on the tires, turning them into a giant spring. So the KYBs are a good choice, giving 8 ranges of stiffness from OEM up- personally, bang for the buck KYBs are better than the HALs, since you don't need to use the HALs first 4/5 settings, which are softer than stock, in the rear.
So as far as my street set up, I'm stock shocks in the front and I run 1 or 2 on the KYBs in the rear. I prefer 2, but my wife bitches about the ride so I'll put them to 1 to appease her.
As far as your 10 bolt ... I'm now on my third set of Hoosier QTPs and the rear is holding up fine.
Since you have the HPP3, if you haven't done so already go ahead and calibrate for the 4.10s
Good Luck
4.10s with an auto is so cool. My friend has them in his 69 Camaro auto...Hell I think you should keep them...I want to get some 4.56s for my 12-bolt but I am too cheap...But my car is a 6spd too...My dad used to run 4.88s to 5.13s in his 62 Impala which was a 283 with a powerglide(for those that dont know its a 2 spd auto trans)
97 LT1 6spd TA Silver
98 LS1 6spd TA...Mystic teal
Mods-
Moser 12-bolt 33spline axles, larger wheels studs, Auburn Posi, and 3.73s
Kenny Brown Double Diamonds
Global West Lower Control Arms
Global West Panhard rod
McLeod Twin Disk Cluth w/ Adjustable Master Cylinder
Flowmaster Muffler
Cutout
92 CAMARO Z28 HERITAGE PACKAGE- T56 TRANS, CAM, COMPUTER, FRESH PAINT (RED WITH BLACK STRIPES)FOR SALE!!!
Mods-
Flowmaster Muffler
Cutout
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
