How Much More RWHP To Go From 12.8's to 11.8's?
Assuming that hooking up isn't a problem. How much RWHP would I need to add to my car to go from my current 12.8's into mid to high 11's.
I'm just about to add stage II heads, LS6 intake, Cam and Ed Wright computer program. I'm currently running 12.8's where will this new package take me to?
Thanks,
Thanks,
Bill
Click here for my best strip time!
98 WS6, Nitto 315/35/17's,MAC Headders and Off Road Y-Pipe, Flowmaster American Thunder Catback, Vig 3200 Stall, TransGo Shift Kit, MTI Clear Lid, K&N Filter, TR55 NGK's, Taylor 8mm wires, EGR MOD & Other Free Mods. 12.84 @ 104.15 MPH 60ft 1.73.
Thanks,
Thanks,
Bill
about 100rwhp.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
I agree with the last poster. Ballpark 100 rwhp. Depending on whose H/C you go with, in an A4, you should touch the 400 rwhp mark (or be pretty close) and be darn close to the 11's. Though you might be sitting low 12's, IMO.
It will take less than that if you step up with a looser stall torque converter. You should send your Vig back to be restalled to a 3600. It will match the new setup better since virtually any decent aftermarket cam is going to raise your peak TQ.
'02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A.
naturally-aspirated with bolt-ons, a cam, and a fat converter!
L.G. Motorsports (972) 272-7753
Check out the SS!
Check out the SS!
100 sounds about right
-94 Trans Am 25th Anniversary Edition, A4, 13.969@99.19mph
-Borla cat back
-Moroso CAI
-160 Thermostat
: http://members.cardomain.com/hellspawn
-Borla cat back
-Moroso CAI
-160 Thermostat
With that V3200 you should be able to cut low 1.6x 60s. ... that a couple of tenths of the time right there - it'll take you some suspension work and meater tires.
15" wheels all round with some skinny tires up front will also help.
I don't know what the typical DA is where you are running, but with your mods it seems that there should be a little more mph. Maybe a ported TB or at least the bump stop mod. I assume your running !FRA, have you consider an induction system or the FIPK. If you're not running a cutout, you may want o consider that also.
A little tweaking here and there and you're present setup could be close to 12.5 or better - remember you're going to need all you can get, because once you hit the 11's you will have to turn around and give some of it back with a roll bar.
Good Luck
'01 Mystic Teal Z28
A4/3.23/Leather/T-Tops
Mods List Here
12.38/110.72/1.74 60'
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
"To play it safe is not to play"
Good Luck
'01 Mystic Teal Z28
Mods List Here
325 rwhp/341 rwtq
www.MysticZ28.com
NorCal LS1/LT1
