How much oil?
Old 08-01-2002 | 08:34 AM
maddboost's Avatar
Post How much oil?
Im planning on changing my oil in my 98 Z28 next week and was wondering how many quarts to put in? In doesnt say in the manual?
98 Red Z28 A4 bought on 4/02/02.
Flowmaster, K&N Filter, Flowtech Dump pipe.
Best 1/4: 13.554 at 102.62
Old 08-01-2002 | 08:37 AM
jp2002ls1's Avatar
Post
Buy six quarts, you will probably need between 5 1/2 and 6 depending on how much drains. Just add 5 quarts then start your engine let it run and check the dipstick and then add more. I assume you are also changing the filter.
Old 08-01-2002 | 01:01 PM
ZZed's Avatar
Post
5.5 quarts. A little more or less won't hurt much. Just watch your dipstick. LS1s are known for higher than average oil cunsumption. The manual should have all the dimensions and specifications for you car. Oil, antifreeze, tranny, and rear-end fluids are in there. Keep looking.
Old 08-01-2002 | 01:25 PM
supersp0rt's Avatar
Post
buy 6, put 6 in...period.
1999 Camaro SS A4 Black/Black/Dark Gray w/ Torch Red Hood Scoop and Torch Red Rear Stripe... 3:23 || SLP Loudmouth || SLP AirBox Lid w/ K&N || SLP Bowtie Grille || SLP CAI || SLP SFC || SLP STB || AZP&S Adjustable Fuel Pressure Regulator w/ 3psi Boost || Sullivan Aluminum Racing Pedals || Yank ST3500 || B&M 24K Tranny Cooler || Jet-Hot Hooker LT Headers w/ ORY || Hypertech 160 T-Stat || SLP Fan Switch || 17 x 9.5 Aluminum Z06 Wheels || Nitto 555R's || Macewen White Faced Gauges w/ Red Dash Bulbs || Xenon Headlights.
Old 08-01-2002 | 05:47 PM
mmannSS's Avatar
Post
It is in the manual. If you look in the index under fluid capacities I believe. I know because that were i got it from. True it isn't in the engine oil section (they're a little tricky aren't they)
2002 Camaro SS #2288 M6
!CAGS
Stock Dyno Run with 5,460 miles:
RWHP 302
RWTQ 320
Old 08-01-2002 | 07:06 PM
PhantomTA's Avatar
Moderator
Post
Its in the back of the manual
5.5
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
RX Speed Works
07-24-2015 02:25 PM
big_mac421
07-13-2015 03:48 PM
jl1ne
07-07-2015 08:38 PM
streetbad
Advanced Tech
07-05-2015 10:40 PM
SergheiS
07-05-2015 03:27 AM
Quick Reply: How much oil?
