how much power and other questions
#16
nothing like spacing out buying your mods. lol you should expect to see decent power. I personally wouldn't bother with the gears in the rear. you have a good chance of blowing the rear when you put a little extra power to the motor. i would hold off on the gears, besides it will cost you about 500 for the gears and the install, thats like 20 to 25 % of the rear.
#17
another thing is that you are going to make all this power, but you aren't buying anything to put the power to the ground. I would personally do my suspension first, which is what i did. then rear, then trans lastly the motor. You might want to add a scattershield to that list so that you don't chop you legs off in case that clutch blows apart. it does happen
F'n1996Z28SS
08-23-2023 11:19 PM
