how to tell if its my water pump
Old 11-22-2003 | 10:34 PM
JeffHooke's Avatar
Well I'm leaking something (water maybe?) heavily out the bottom of my car but can't tell exactly from where. The dash gives me a low coolant light but the coolant level is definitaly fine. Are these problems related and is it the water pump? Thanks for any help
Old 11-22-2003 | 10:39 PM
kick Z tail out's Avatar
Look at the water pump and see if it's leaking.
Old 11-23-2003 | 10:01 AM
DirtyDan's Avatar
Are you checking the coolant tank or are you actualy checking inside the radiator?
Old 11-23-2003 | 10:09 AM
Shockwave's Avatar
Lounge Moderator
A much better question for LS1 Tech than the Lounge...
Craig
Old 11-23-2003 | 03:33 PM
JeffHooke's Avatar
I'm checking the tank. Today and yesterday the thing started going down so I added coolant. However the car still runs about 210*
Old 11-23-2003 | 06:21 PM
jakesnake123957's Avatar
You can rent a cooling tester from auto zone,that will tell where the leak is.Could be you coolant sensor is bad too,mine makes the light flicker off and on,my coolant is OK however>Jake
HectorM52
07-30-2017 11:46 AM
Biggiebound
04-21-2015 11:28 PM
KYWes
04-15-2015 07:28 PM
Blood type Z28
04-08-2015 11:34 PM
pologreen97z
12-02-2014 10:42 AM
Quick Reply: how to tell if its my water pump
