I cant get my car to stop pinging!
Old 08-05-2002 | 01:42 PM
  #16
Btchslp's Avatar
Arrow
Oh yeah, Trevor98 is a salesman. Porting your own mafs is a great free mod. Take heed to someone who is trying to sell you something. The GMAFs are having a lot of problems and the price is ridiculus!
99 SS, Dark Metallic Blue, M6
SLP lid, KN, TBB, SLP Y-pipe, SLP loudmouth
ported MAFs, Fernco, Nitto 315 DRs
Currently: 1/4 13.15@114, 0-60 4.85 (w/passenger) Gtech'd
Old 08-05-2002 | 01:43 PM
  #17
ratio411's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Desolate_Flux:
Question - What is pinging? I mean, how will I know if it is pinging, what does it do, whats it sound or feel like?</font>
Pinging= Detonation
This is when your air/fuel charge entering the combustion chamber ignites at the wrong time. It's usually due to hot spots in the chamber. Since the explosion is supposed to happen with the piston at the top of the cylinder poised to go down, but doesn't... you can hear the flame front hitting the top of the piston doing bad things.
To give you an idea of how bad detonation is to your engine, inaudible detonation can destroy an engine. Audible detonation is that much worse.
Audible detonation sounds like a jar of marbles being shaken under the hood.
An engine will almost never detonate unless it is under heavy load, either hard acceleration or easy acceleration in too high a gear (lugging).
You can reduce detonation in several ways:
Cool the combustion chambers with a low temp stat, fan switch, larger radiator, TB bypass.
Make sure you are running the highest octane fuel available to you. 91-93 The higher the octane the slower the fuel ignites making it resistant to hot spots.
Keep uncontrolled oil out of the chamber, or anything else that drasticly lowers octane when mixed with fuel.
Richen the A/F mix slightly... can reduce performance if you are not careful.
Run a lower heat range spark plug... can reduce performance.
Hope this helps
If I left anything out, I'm sure someone else will jump in.
Dave
Old 08-05-2002 | 01:47 PM
  #18
ratio411's Avatar
Angry
<font face="Verdana, Arial" size="2">Originally posted by Btchslp:
Oh yeah, Trevor98 is a salesman.</font>
I was noticing that he was pushing some kind of product in every post. Definately annoying knowing that he only has his pockets in mind when folks are asking for help.
Dave
Scottylt1
01-08-2015 02:48 PM
ANDYZ28
12-29-2014 09:13 PM
Noenav
12-06-2014 07:35 PM
USAirman93
11-24-2014 03:37 PM
GigaMp3z
02-20-2003 02:57 PM
Quick Reply: I cant get my car to stop pinging!
