I heard 98's dyno lower...
#24
Originally posted by AL SS590 M6
What did it MPH in the 1/4????
2nd run was 13.23 @ 105.5
and 3rd run of the day I went 13.09 @ 105.8
I eventually got it down to a 12.88 @ 106.6 with just a K&N and cat-back.
#26
My 2002 M6 dynoed 299.7 hp/317.5 ft lbs with a SLP lid and a K&N (the K&N is worth less than 1 hp from what I've seen). That is the lowest I've ever seen a 2002 M6 dyno. It had 5,500 miles on it at the time. My only drag strip pass was not a good test (1.09 light, 2.6 60ft and nearly stalled it, launching at 900 rpm and a 14.04@102.5). I'm sure the car would go faster, but that was on a 90 degree day (before I'd mailed the first car payment on it) and I was going real easy on it.
Of course, by the 4th dyno pull, my hp was down into the mid 280 hp range. I suspect the car was not cooling properly on the dyno and that may have been part of the problem.
#27
I have a 98 M6
I pulled 318/328 with a Dynomouth and lid (paper filter).
It was one pull, very hot day.
Concerning some previous comments:
Lower gears cause lower dynos. Not vice versa.
Autos dyno lower because of more parasitic loss, but tend to be faster at the track due to consisent shifting. M6 with traction has the edge, but only with a very good driver.
The 98 cam is better, the later cars got the truck cam to detune them a little. The exhaust, intake, and other revisions called for a smaller cam to keep power in check.
Later cars are said to dyno ~10 higher, this is what I have seen myself, but there are factory freaks both ways.
I have seen 2 dynos that were later cars with my exact same mods and they were exacty 10 rwhp higher.
Dave
Dave
#30
Originally posted by falchulk
Are you sure about this???
