I need a cam recommendation, lots of info to work with...
Old 12-29-2003 | 01:00 AM
Timberwolf's Avatar
I'd like to run 420-450 SAE rwhp, and hopefully in the 117-120 mph trap speed area.
Don't want to fly cut the pistons if I can avoid it. I'd like to be able to throw a little spray into the mix down the road too, but it will be rare occsions it's used.
Car is a 99 Z28 convertible. 3.73 gears, auto trans, Yank SY3500 converter, ET streets, Mac mid lengths with ORY and SLP TOTL cat back. Cutout is planned too as is an ls6 intake. I haven't decided on any throttle body mods yet.
Heads have 2.02"/1.575" Stainless steel REV valves,Brand New Comp Cams 918 Blue stripe updated spring's with matching retainers,New Felpro LS1 Valve guide Seals,Bronze/magnezium Valve guides,Full CNC Stage 2 Port program by CNC Inc in Penella's Park, FL. including CNC chamber,Full Hand blending, porting and Re-shaping of intake and exhaust runners, Competition 3 angle valve job radiused to spec, and head's are milled .030".
.200: 152/117
.300: 205/163
.400: 256/201
.500: 289/219
.550: 302/224
.600: 311/226
Chrome Moly comp cams pushrod's,Felpro LS1 head gaskets and New Head bolts
Old 12-29-2003 | 05:01 PM
PhantomTA's Avatar
Moderator
Just PM me ******* and ill get you a cam.
rideordie
11-05-2019 04:52 PM
jayblev95
East South Central
02-15-2015 02:26 PM
jayblev95
01-06-2015 11:52 AM
Queens94z28
12-20-2014 09:11 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: I need a cam recommendation, lots of info to work with...
