I seem to have a squinking noise from the back.
Old 04-09-2005 | 11:09 AM
Beefcake01's Avatar
When I drive over bumps and even shut the door at times the car makes a squinking noise or something. I run a cutout so I do not know if vibration has done something, but what can I do? The noise does not occur all the time but it does occur enough that I want it fixed. Thanks.
Old 04-09-2005 | 03:08 PM
Reznor's Avatar
Re: I seem to have a squinking noise from the back.
i recently put a cutout on my car too, and noticed a squeeking a couple of weeks after.
could be the stock exhaust. try moving it and see if it squeeks. i got under the car and WD40'ed everything that holds it up, and that fixed that problem.
Old 04-10-2005 | 11:07 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
i too noticed my "sway squeak" went away when i cut my exhaust out...
so just cut your exhaust out and you should be good
or... i guess you could go the wd-40 route... but thats no fun.
magman
04-15-2016 03:08 AM
autoxr166
09-25-2015 04:21 PM
rideordie
09-07-2015 08:22 AM
CARiD
09-07-2015 08:21 AM
08-05-2015 08:35 AM
Quick Reply: I seem to have a squinking noise from the back.
