Idel Engine Temp for LS1
Just thought I'd share this with the talk often of getting lower thermostats for the LS1. It may have been a better mod for the LT1. Makes a lot of since to me. Later >>>>>
http://www.ls1info.com/article.php?sid=267
Good article. I'm sure some people will have other opinions. I have always wondered why people thought that their engine would run better at a non-stock temp? I'm sure that GM engineers set all of the internal clearances where they wanted them at normal operating temp. Changing this temperature will change clearances and it seems it could cause a lot of trouble for the 1 or 2 horsepower it is worth. Also, is there a good reason that we don't have 180 or 160 stats from the factory? Its not like they are more expensive, so why didn't GM use them? I assume they had a reason, does anyone know what it is?
180 Thermo in the LS1 Already?
Hey Dkeers, here is another article that talks about your question.
Later>>>>>
http://www.ls1info.com/article.php?sid=184
Later>>>>>
10-31-2016 11:09 AM
ChrisFrez
11-23-2014 10:33 AM
07-04-2005 05:00 PM
ZBLKHELLRZR
08-18-2002 07:57 AM
Darth Xed
13
07-22-2002 12:45 PM
