Illegal Exh??
Old 07-24-2005 | 07:30 AM
Bayer-Z28's Avatar
Illegal Exh??
This might sound stupid, but I thought it was a little too techy for the lounge..
What makes headers so illegal?? Even if you still have cats and the O2's are in good working order..
What are some tips to passing inspection... I don't have an anual inspection in CT every year, just emmissions every two or so years.. Pluss I'm moving to NM next month so I want to be prepared for anything..
Thanx yall..
Old 07-24-2005 | 07:37 AM
99blackSS's Avatar
Re: Illegal Exh??
The technical reason that most headers (the good ones ) are illegal is because they move the cats back. Moving the cats back generally decreases there effciency even if the car still passes smog.
I have mids with cats that passed the sniffer. I think the key is finding a shop that isn't too **** about the visual and then getting cats so you can pass the sniffer.
Old 07-24-2005 | 09:44 AM
Bayer-Z28's Avatar
Re: Illegal Exh??
Crap. I didn't realise that I posted in the LS room.... Sorry...... I was intending for it to be in the General F-Body room...
Old 07-24-2005 | 09:59 AM
Kris93/95Z28's Avatar
Re: Illegal Exh??
A few more points to his statement:
Headers that don't have all provisions for emissions equipment are illegal. So if the stock manifolds have EGR hook ups, they need to be retained.
It is also illegal to change the NUMBER of catalytic converters. So that too makes LTs illegal for single cat cars. So if you go from one to two, you're breaking the law <~ It doesn't make sense to me, but thats the law, I guess...
Old 07-25-2005 | 01:01 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
Re: Illegal Exh??
ANYTHING having to do with changing the number, position, size, kind, placement of the catalytic converters is technically illegal...
typically if you HAVE cats (hi flow - pass visual) that work (pass sniffer) you will be ok.
no guarentees tho
just register your car in a state without emissions
like mine
Old 07-25-2005 | 10:50 PM
thirteen20z28's Avatar
Re: Illegal Exh??
What also seems to be the issue is that even if visible parts have no effect whatsoever on emissions, the companies that make them choose not to get them approved (thru CARB, etc.). If they can sell enough without a CARB EO# , they have no reason to spend the considerable amount of time and money it takes to get one. So even if a part isn't officially "emissions legal", that doesn't mean that it hurts emissions.
Quick95Z
02-14-2003 01:08 AM
2turboz28
V6 Tech
01-02-2003 12:50 PM
sideways_Into_3rd
Advanced Tech
12-11-2002 06:11 PM
Timberwolf
Advanced Tech
08-05-2002 10:35 PM
Quick Reply: Illegal Exh??
