induction options?
Old 01-16-2006 | 09:52 PM
LarrieuY2KSS's Avatar
induction options?
I am in the market to finally upgrade my stock induction set up and would like to get some ideas on which avenue to go with. What do i really need lid, maf, etc.......?
Old 01-17-2006 | 04:35 AM
rskrause's Avatar
Moderator
Re: induction options?
I think you'd be better off posting this in LS1 Tech.
Rich
Old 01-17-2006 | 08:17 AM
SSpdDmon's Avatar
All you really need is a lid and maybe a ram air kit like the Super Sucker or FTRA. Above and beyond that, you're just doing engine bay appearance mods. As for the MAF, I say leave it alone. You might be able to flow a little more CFM by porting/descreening or buying an aftermarket piece. But, the amount of headaches that can be found after people have done that suggest not to mess with it. The stocker should be good to about 550~600hp anyways. So, save your money for something like headers or a cam. Just my $0.02.
Old 01-17-2006 | 08:25 AM
00cls1camaross's Avatar
Buy an intake lid from any one you want... and aftermarket intake lid is and aftermarket intake lid...
you can buy the bellows if you want, some people say it is a waste of money, others do not... it adds around .0000001 hp to your car so you can determine if it is a good bang for the buck
the MAF is a waste of money to replace it considering gains are very minimal (less than 5 hp), you may want to just descreen it and call it a day until you get a massive H/C setup. Some will say to descreen it and others wont, just be careful when you do it and it will be all good
For the TB, just have someone port it for you, or port it yourself. It is a waste of money because like a MAF sensor gains are very minimal
As for the intake manifold, if you dont have a 2001-2002 ls1 then you dont have an LS6 intake manifold. SO.... if you dont have that year, that is a good investment which should help out w/ power all across the powerband... i'm sure someone who has actually had experience with this will explain more
SSRA (super sucker ram air) is a sweet ram air for Camaros/Firebirds... it is this little air ducting that runs from the bottom of your Intake Lid and down to right in front of your radiator... at low speeds it acts a just a cold air induction and at high speeds it acts a a ram air.... i think if i recall it is like 13 rwhp at 60 mph....
Last, if you cant afford the SSRA you can do a mod called Free ram air... consists of cutting some stuff under your intake lid, bending some plastic and getting a few hp... look it up on google, they will tell you how to do it
Take it easy and happy modding!!!
-Dakota
Old 01-17-2006 | 09:20 AM
teke184's Avatar
what he said.
all lids are about equal, only real difference is price and appearance.
the SSRA is a very worthwhile mod, particularly for non ram-air equipped cars. even on the SS since the air inlet path for the SS hood is less than optimal. the intake path on the WS6 cars is much better, and doesn't really need a new ram air.
i wouldn't port the maf, but porting the TB i think is worthwhile, specially since it is something you can do yourself or for very cheap. i calculated it out to an 8% increase in cross sectional area by removing the lip just in front of the tb blade.
check out the bottom of page 2 of my website (in sig) for a pic and explaination.
Old 01-17-2006 | 10:35 AM
Greed4Speed's Avatar
Since yours is a 00 model, an LS6 intake would be on the list also.
Old 01-17-2006 | 11:00 AM
Kraest's Avatar
Retired
I'd do the basic bolt-ons... Lid, Headers, Exhaust, etc, then focus on what else you want to do, such as Cam, heads/cam, nitrous, supercharger, stroker motor, etc.
Also, I'd check out Futral Motorsports. They are about 45 mins away in Walker.
Ks0209
10-01-2015 07:32 AM
NewsBot
09-30-2015 04:20 PM
CARiD
09-30-2015 05:44 AM
sleeperZ96BT
09-10-2015 08:01 AM
Quick Reply: induction options?
