Just dynoed for the first time... Tell me what you think
#17
Originally posted by AL SS590 M6
Mark,
Don't ever be disappointed by dyno number comparisons.
Point in case....................check my sig.
I'll bet there are a lot of cars out there that dyno more than my measley 312hp that don't run the numbers that I do at the track!!!!
Dyno numbers are only good to compare your car before and after mods.
Mark,
#18
Originally posted by mark896
No worries. It seemed that since you decided to go into detail about my signature (with the red highlight and everything), maybe I should go into even more detail about the specifics of it. Thanks though, I guess.
but just wanted to type less. red was shorter..
I often disect sigs.. i feel it helps new members and lurkers understand that some mods arent really mods.. just a way of spreading more information
#20
Originally posted by psychocabbage
how repeatable are those numbers?
I go to the track a lot, 350+ passes in 3 years. (and that's on the origional 4L60E) And I document everything. I take a weather station with me. I can pull in, get the weather station out and tell you within a half of a tenth what I will run. Most days I run within a few hundredths of my dial.
#21
Originally posted by danno02SS
Where the hell are you running? Death Valley?
I was at Stanton, MI alt ~700ft
temp 45°
humidity 50%
Baro 31.2
There's a guy in the drag race section with a bolt on LT1 that ran 11.s. The DA was -1900ft.
#22
If I were to go to the track again when the DA was -1300 I would run the same numbers. If it were 80°, 80 humid, and 29.9 baro I'd run 12.50s or there abouts. Weather conditions play a huge role in the making of HP at the track. Whereas dyno readings are corrected to a set of standards.
I think you would not see times like that here.. even though we are near sea level.. http://www.houstonraceway.com is our local track..
tdigger9899
09-07-2015 10:56 AM
