A little advice on heads.
Hey guys I've decided to go with a H/C package for my Z28. I've decided to go with Patriot Performance Heads.
I was just wanting to know which ones to go with?? I plan on keeping this a N/A car as I feel after the H/C package and some Headers I should be fine.
My question is which ones?? Stage 2 5.3L, Stage 2 5.7 L, or the Stage 2 LS6/LQ9 heads.
What are the pros/cons of each.
thanks.
thanks.
Depends on the money you want to spend. Personally, I'm going Stg II LS6 heads. They're pretty damn good on the price, and obviously they'll be better than the others. You just have to figure out a budget. Going fast is all about the Benjamins
Well as far as the $$ goes I believe you should get what you want Plus I was looking at the package at texas-speed with a custom TSP cam, hardened pushrods, and roller chain for like $2300 or so??
So the Stage 2 LS6 heads are the big dogs then??? I've heard people liking the 5.3 cause it raises compression. What does the LS6 do as far as that??? Does anyone know??
Thanks for input.
Thanks for input.
Thanks for input.
Thanks for input.
Not to sure on the 5.3's CR but on the LS6 style with 59cc my CR is 11.1.1-11.2.1. I hope this helps.
I opted for the S2 LS1 heads.
However, there were 2 deciding factors ...
Price: I have a '98 and they are on sale right for $995 a set for perimeter bolt heads
Future: I road race and need a good power, but for extended periods of time. A huge cam is just not the ticket for my needs, so there was no need to go with monster heads.
Also, once you get into the 11s on compression, tuning becomes a major issue if you chose to daily drive it. Cold start, return to idle, low vacum, fuel octane, detonation issues could all make a BIG cam a royal PITA ...
Well i wasn't going to go with a monster cam. Just an agressive street cam.
What difference does the combustion chamber size make?? They have 2 different ones for the same LS6 heads.
Also whats the stock compression on our cars??
Sorry for the long post but here's what I'm looking at:
25-PPstg2-5.3 Patriot Performance Stage II 5.3L Cylinder Heads, TSP Custom-Grind Camshaft, Hardened Pushrods, Rollmaster Single-Roller Timing Set $1,869.99
25-PPstg2-5.3231 Patriot Performance Stage II 5.3L Cylinder Heads, TSP 231/237 or TSP 231/231 Camshaft, Hardened TSP Pushrods ON SPECIAL $1,675.00
25-PPstg2-5.7 Patriot Performance Stage II 5.7L Cylinder Heads, TSP Custom-Grind Camshaft, Hardened Pushrods, Rollmaster Single-Roller Timing Set $1,869.99
25-PPstg2-LS6 Patriot Performance Stage II LS6/LQ9 Cylinder Heads with 72cc Combustion Chamber, TSP Custom-Grind Camshaft, Hardened Pushrods, Rollmaster Single-Roller Timing Set - ON SPECIAL WITH FREE SHIPPING! $2,299.99
25-PPstg2-LS6 Patriot Performance Stage II LS6/LQ9 Cylinder Heads with 59cc Combustion Chamber, TSP Custom-Grind Camshaft, Hardened Pushrods, Rollmaster Single-Roller Timing Set - ON SPECIAL WITH FREE SHIPPING! $2,299.99
There are two LS6 a 59cc and 72cc and it says they're LQ9 which i think is the 6.0 Heads.
Wow some good stuff but way over my head
Well then how bout some advice. Of the packages in my above post which one will be best for me :
1. Daily driven
2. Kick A$$ Car
3. Reliable
4. Stock bottome end
5. Wanting about 400 or so RWHP
On stock deck heads, with a decent custom port job, TR220/.558/114, LS6 intake, FLPs and custom tuning, I made 380/380.
Very mild mannered and works very well on the street. Gas mileage never suffered and it will easily pass emissions testing.
I too am looking for that magical 400rwhp AND torque
I am going with the LS1 Patriot S2s milled .020 to get my compression ratio up to about 10.5 or 10.6. The Patriot heads flow the same as my current heads up to about .500 lift and ramps up significantly at .600 lift.
I feel as though these heads will get me to 390, probably ... maybe. A cam change to a TR224/.561/114 should make that goal achievable.
The CR is low enough that pump gas will still be just fine
To be honest, I would do some more research and not take some stranger's advice off of the internet. The information you seek is out there ...
WobblySausage
10-07-2015 10:09 AM
