Little help please
Little help please
K today i noticed my front drivers side orange parking light is out and the lense is cracked..where should i get the bulb and lense from? cheapest? part number? it is called a daytime running lamp right?
also my left turn signal is stuck..i tap it and it sticks on the dash and the rear light sticks? burnt out bulb? part number for the rear burnt bulb? thanks
am i going to have to get the DRL lense from the dealership and get raped?
Re: Little help please
k from what ive read..if i turn the left signal on and it sticks and i go outside of the car and see that the rear left light is solid lit (not blinking) and on the same side the front signal (daytime running light) is out..then all i need to do is simply replace the front bulb and everything will be good. sound right?
i need a drivers side front DRL/signal lense and bulb..is the bulb number 4157NAK? get lense from dealership?
This place has reasonable prices:
http://www.gm-car-parts.com/gmautoparts.htm
This seller on ebay has repro parts cheap:
http://stores.ebay.com/ZBRA-Motors_W...Q3amesstQQtZkm
