Long Tubes??
Old 02-20-2004 | 12:14 PM
  #16
02newtZ's Avatar
i believe the long tubes will will more up on high end of the tach, and the shorties like to make more low or mid-range power. i take in to consideration your current or future head/cam selection. where will your shift points be?
Old 02-20-2004 | 01:46 PM
  #17
Sparkz28's Avatar
thats not right....
long tubes make more mid range power....
a good set of mids or shortys will make more peak Hp....up in the 7,000 range
Old 02-20-2004 | 02:46 PM
  #18
danziger's Avatar
Thumbs up
I had MAC mid-lengths and was very pleased with them on a bolt-on only car. Now that I have heads/cam, I went to LTs to take advantage of the added airflow. Only shorties will work with your stock-length Y-pipe. However, since you are running an off-road pipe it would seem that emissions aren't an issue, so why not go to at least mid-lengths?
RUENUF
05-25-2016 08:10 PM
RUENUF
03-13-2016 03:39 PM
MDZ28
Exhaust System
06-02-2015 09:48 PM
SpeedJunkee
12-09-2014 10:17 PM
Quick Reply: Long Tubes??
