looking for head and cam combo
Old 02-09-2009 | 10:12 PM
gilbe01ss's Avatar
i have a 2001 ss it is mostly stock. i am lookign for a head and cam setup that will give me alot of horsepower. i want a cam that will give my car a rough idle but is still streetable. someone out there must have a setup like im looking for, if anyone knows anything about it please let me know i am lost. tahnkyou
Old 02-10-2009 | 06:11 AM
AL SS590 M6's Avatar
Moderator
Why not read all the heads/cam/build up posts in the first 3 or 4 pages of this forum, get some ideas then ask questions.
Old 02-10-2009 | 09:43 AM
Chrome383Z's Avatar
Just depends what you want man. A budget build with a Cam/243 Heads like i'm doing now can get you around 420-440rwhp.
Send those heads out to be ported by AI or get a set of aftermarket heads + a bigger cam and 460-480rwhp.
***** out 500rwhp can be hit with a perfect combo.
Just depends on what you want. I'd concentrate on Bolt-Ons/Clutch first though...450+rwhp is worth nothing if you toast your clutch or grenade your rear end the first time you hook!
Old 02-10-2009 | 12:00 PM
Shon Herron's Avatar
Get the bolt ons first and then go to the H/C, b/c if you are stock right now, you are doing nothing but hurting the combo with stock parts.
Start out with headers and go from there. I will help ya any way I can and once we get ready for AI H/C we can do that too.
Old 02-10-2009 | 02:49 PM
chrisw27's Avatar
thunder racing 231/231 cam did 400 with stock ls1 heads and intake. go with that cam, fast 90/90 setup, and trickflow heads you will be around 460-70 hp. if you want 500 try the trex like i have in my racecar cam only car.
Old 02-10-2009 | 02:53 PM
500 cam only? 241 or 243 heads?
BTW- you dont need TFS heads to make that 460+ power, some 243s worked right with a 230ish cam will do just fine.
Old 02-10-2009 | 04:57 PM
WhiteHawk's Avatar
How much do you want to spend? Then you can get some accurate suggestions. Are you going to have it installed and tuned or are you doing it yourself?
-Geoff
10-31-2016 11:09 AM
StansZ28
02-19-2015 07:39 AM
kaoticcamaross
02-17-2015 03:13 PM
birdblack
12-30-2014 06:59 PM
Queens94z28
11-20-2014 06:03 PM
Quick Reply: looking for head and cam combo
